System Manager received a negative ATG_FT_PARTNER_NEW response message. System Manager attempts to retry sending the message after a delay.
This is likely to be a configuration problem.
Warning
System Manager received a negative ATG_FT_PARTNER_NEW message. Master entity type = %p1% Master entity index = %p2% Slave entity type = %p3% Slave entity index = %p4% Primary slave instance index = %p5% Return code = %p6%
| Name | Type |
| p1 | xInt32 |
| p2 | HexByteArray |
| p3 | xInt32 |
| p4 | HexByteArray |
| p5 | xInt32 |
| p6 | uInt8 |
